Which is better on wood? Polymer clay or Air Dry clay?
I ws going make a wand out of wood, and I was making the handle out of clay. The problem with polymer clay is I can't use the oven, and the problem with air dry is I don't know if it will crack when it's dry. Which one???
KentsOkay8 years ago
Try the air dry first, if it doesn't work, make sure your wand wood is very dry and use polymer. You want to avoid the oven because the heat may cause the wood to split
