Which knex sidearm should i build?
I don't generally use primary weapens, besides shotguns, but which sidearms are the best of the best of the best of the best of the best? It can range at any pieces, just as long as it shoots pretty far without having to put 5+ bands(my ahnds get sore when i pull them, i mean like with my bands a normal knex gun shoots 1.5x or double the range. I'm looking for sidearms withing this category-realistic(optional),no block trigger(any beside that),mag-fed (preferaably through the handle but doesn't really metter), no jams(yes no jams). I'm oing to make my own but until then i just need a good one....My current one is the TDSS(TheDunkis Slide-action Sidearm) because it fits above categories.
try this one by Killer~SafeCracker
https://www.instructables.com/id/TBAP-Thunder-Bolt-Assault-Pistol/
it features a true trigger, 20 round magazine (it shoots oodammo) and jam free
knex_mepalm (author)  Shaznazabbadaz8 years ago
18 rounds was the only rhat worked for me, jam is on last bullet, and otherwise its pretty awesome...
ok
Thanks man.
no prob, your gun is my favorite sidearm!
~KnexBuild~6 years ago
Try the AST pistol by I Am Canadian
knex_mepalm (author) 8 years ago
Ok, i need a gun which feels like a bull ramming into you, no need for distance, just strength, i'm having a war in 3 days!!! HELP!!!
then you definitely want oblivitus's beast pistol, that thing KILLS! i also have my side-arm the lucky 13 that fires red rods, but Oblivitus's beast pistol is the best. or if you want a larger mag, use BB's rising sun.
knex_mepalm (author)  An Villain7 years ago
 You were right, I worked up the courage to send my money to knex.com then got some pieces for it. I killed a squirrel accidently, it hid behind my wooden target and the target fell and it went smoosh. The target had a rather large hole in it. Does this count as a sin? I think the squirrel was preparing for hibernation.
oh dear. but no sin, it was an accident.
Problem with that is the jamming issue.
mine never jammed.
Didn't it? Mine did and according to oblivitus his did too! He said you have to shake it when it's nearly empty.
mine did that once, but i do not consider that a jam, a jam is when more than 1 shot tries to load into the barrel at once, the shot snags on the ram, or so many shots try to go into the barrel at once that none of them can move forward, i consider those jams.
Yeah well it's still a malfunction
no it is not a malfunction, the definition of malfunction is: anything that is not supposed to happen during the use of something, but it is not a malfuncton because, it is supposed to work like that.
What, the bullet is supposed to not come out sometimes?
no, it needs to be shaken sometimes.
Yush, I that needs improving. Actually when I had the beast pistol I modded it slightly so it would have a basic pusher: problem solved!
i don't think you can have a pusher on that, and it would lower the range drastically.
Didn't seem to affect it for me...
it does though.
OK all I ever used it for was plinking around in my 50ft garden and it could shoot from end to end, so meh I wouldn't know :)
it does lower the range, but when you are only shooting that far, it does not seem as bad as it is, also i think it looks better without a pusher. that is why i like the L.A.M.A.R. and viccie b1993's EDR45AP, because they have internal pushers.
knex_mepalm (author)  An Villain8 years ago
If i shoot my friend will he feel like hes lucky to live?
oblivitus's beast pistol hurts like no other side-arm, best in its category. but BB's rising sun also hurts but not as much as oblivitus's beast pistol, or you could build a crossbow pistol.
rising sun? i searched ibbles but cannot find it!!
it is on Knex innovation . net.
its not the best but i like the thunder bolt thingy on here
they are all good for their own reasons, the TBAP has a very large magazine capacity but uses hinges and is not compact. the Oodammo pistol by TD is very compact but has a low magazine capacity. and the rising sun is powerful but has a medium capacity and does not look finished (easily remedied.)
which one can do massive damage? like the most?!
Mine does lots of damage (I know this is an old convo lol) as it has a 16 round mag, huge range and shoots RODS, so you can sharpen them!
rising sun is the most powerful but has no puncture-damage as it uses oodammo, loading oblivitus's beast pistol with sharpened gray rods does the most damage by far (sticks in plywood at point blank.) but if you want true power, use a crossbow pistol. (no magazine though.)
no sharpening allowed and whats puncture-damage
how far it sticks into something.
so it impacts real hared using shared force bult it has low punturing which is force focused on one area
kind of.
Merugop7 years ago
 NB-4 PISTOL
NYPA8 years ago
Oodassault V3.3. BEST EVER. Break action mag. stripper clips ( no, not that. ) and 16 rounds. What else could you want?
i would say that mine is good but the elastic bands are hard to balance out
knex_mepalm (author)  The Fishfrog8 years ago
ill build it, and by the way, they all are...
I would never use the TDSS in a war. I would use my TBAP.
knex_mepalm (author)  Killer~SafeCracker8 years ago
I er modded it to shoot over 100 feet..
Ah I could never get it to leave the barrel.
Lots of major problems with the slide and trigger, but as i said , i modded it
Yep
mine
DJ Radio8 years ago
I have my Jackal v2, it has a 12 round removable clip for green rods, but can be muzzle loaded with bigger rods (bigger than blue) if you run out of ammo.
knex_mepalm (author)  DJ Radio8 years ago
guess what? I found eminem on my enclyclopedia!!!
dats rad dawg.
TheDunkis has a couple good ones. His TDS2 and oodammo guns are good. You might want to look: https://www.instructables.com/member/TheDunkis/
I have a decent one: https://www.instructables.com/id/SN31_Assault_Magnum/
IAC has the "Spiff" but that has a mag in front: https://www.instructables.com/id/Joe/ he has a couple others too.
Oblivitus has this: https://www.instructables.com/id/Oblivitus_Beast_Pistol/
You're gonna have to do some searching though to find what you like as these are only a few.
