loading
Which push button switch works with wall plug-in el wire inverters?
Hi I need a push button switch for this plug-in el wire inverter http://www.ellumiglow.com/Standard-Plug-in-EL-Wire-Inverter-p/eowu01.htm.  I am not sure what the unit outputs as the website does not say.  Can someone link me to a cheap ebay push button switch that is compatible?  Thanks?
First you need to know what the output of the adapter is and if it will work with your EL wire. Once you know the power output you can find a button that can handle that power.
