Why does my Arduino script do the opposite of what I want?
Hey out there! I am trying to write a code for an Arduino project I am working on. I am using an ultrasonic proximity sensor and an arduino nano clone. What I want is that when the object it detects is under 50cm an led turns on. When it senses an object farther than 50cm I want theLED to go off. Below is the script I wrote. The problem is it does the opposite of what I want(objects >50 LED goes on, objects <50 LED goes off). Any help would be greatly appreciated! Thanks!
#define trigPin 3
#define echoPin 9
int LED = 12;
void setup() {
  Serial.begin (9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(LED, OUTPUT);
void loop() {
  float duration, distance;
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = (duration / 2) * 0.0344;
  if (distance >= 50){
    Serial.print("Distance = ");
    Serial.println("Out of range");
    digitalWrite(LED, LOW);
  else {
    Serial.print(distance);
    Serial.println(" cm");
    digitalWrite(LED, HIGH);
    delay(500);
  delay(500);
iceng3 months ago
Could the led be wrongly tied to the other gnd-to-Vcc or Vcc-to-Gnd..
iceng iceng3 months ago
Look at A & B, the output pin is HIGH but only ON with ckt A..
Look at D & C, the output pin is Low but only Off with ckt D..
Click the pic to view the whole image..
Mpc1055 (author)  iceng3 months ago
That's it, THANKS!!!!!!!!!
rickharris3 months ago
Your prog does just what you told it to do:
" if (distance >= 50){ IF the distance (I guess this is the same as object in your question), is greater or equal to 50 then LED Off.
else {
delay(500);"
Swap >= for <=
and swap <= for >= further down.
