Why is my 555 timer keyboard starting with noise?
Hi!!! :/) I have made a 555 timer keyboard using a tactile button series with resistors, but rather than staying silent until I press a button, it makes noise as soon as I start it. All the buttons function properly, raising the note in intervals but it starts with sound. I have thoroughly searched my button/resistor series for accidental bridges between joints but have found none. This is my first "real" soldering/perfboard projects, so mistakes could have been made! Could there be any other reason for this noise? I cannot find somewhere else where the circuit may be completing. I have included the schematic I am using.
Any help would be appreciated ]:>)
Thanks!!!!
Picture of Why is my 555 timer keyboard starting with noise?
iceng7 months ago
To calm a 555 add a 0.01 to 0.1 uF capacitor to pin_5 and ground..
Another concern, is the wiring to the buttons which can capture radio waves and cause the sensitive flip-flops in the IC to trip if there is no calming cap...
ToggleSwitch (author)  iceng7 months ago
I'll add that capacitor! Thanks!!!
rickharris7 months ago
The output of the 555 is dependent on the charging and discharging of the capacitor C1. and resistor R5
When you turn on the capacitor has to go through a charge cycle to set the 555 times up ready for use. I expect this is where the noise comes from.
ToggleSwitch (author)  rickharris7 months ago
I will try letting the capacitor completely charge/discharge.
Thanks so much!!!!
