Why remove the board?
Hello,
Can I ask why are we removing the board from the servo? What does it do? Thanks in advance,
randofo6 months ago
It allows you to use it as a geared DC motor.
If you don't, you will need a control signal to get it to move.
Does "geared" means that the spinning direction is controlled by the polarity?
I ask this because I am not sure of the translation, but I believe that with the pcb in place we must respect certain polarity or we will burn the servo :( and as you mentioned to move it we will need a control signal.
Geared as in the motor is driving a gearbox.
The PCB turns the servo into just a motor connected to a gearbox with no control circuit.
This only works on continuous rotation servos.
Standard servos have a mechanical stop and cannot spin 360 degrees. If you remove the controller board of standard servos, the motor will burn out. Unless - of course - you physically remove the mechanical hard stop from the gearbox that keeps standard servos from spinning 360 degrees.
