Why wont my computer boot? And how can i fix the problem?
i have a Dell Dimension E521 and i try to boot it and all that happens is the power button blinks. any ideas?
audreez7 years ago
open the case and look at the capacitors on the motherboard. if their caps are bent outwards or have gunk coming out of them you need to solder new ones or get a new motherboard. dell's are notorious for putting in cheap capacitors that blow up (check if theres a recall)
you can also try to re-seat the ram/cpu/gpu. if you take the ram out and power up it should give you beep codes.
if that is not the case it could be a failed power supply (not giving enough juice.
gantyman (author) 7 years ago
turns out it was a bad power suppy
rickharris7 years ago
I have fixed several power sockets on Dells - You don't know until the battery goes so low the system cuts off.
NachoMahma7 years ago
.  It may be blinking a code telling you what is wrong. Check your manual or go to Dell's website for more info.
gantyman (author)  NachoMahma7 years ago
it just blinks in one second intervals. i checked dells site and got stuck in a loop from one page to another.
