loading
Why won't this batch script work?
I am making an alarm/timer script, and this line isn't working.:
IF '%TIME%'=='0:18:05.20' (GOTO yes) ELSE (GOTO LOOP)
It works when I put %DATE% in instead like this:
IF '%DATE%'=='03/01/2011' (GOTO yes) ELSE (GOTO LOOP)
It quits really quickly with the first line, but i was able to see what is says, and it says
0:18:05.20 was unexpected at this time.
What's going wrong?
Your batch file will most likely work after 12... if you use double quotes it should be fine... for some reason when you have times returning a space first like " 0:18:05.20" it will cause the error above when using single quotes... so below will work...
:Loop
IF "%TIME%"==" 0:18:05.20" (GOTO yes) ELSE (GOTO LOOP)
:yes
echo Time is an illusion
XOIIO (author)  rocketsurgery6 years ago
BRILLIANT! It works like a charm! Now I can have an alarm on my pc for hwen I am working on stuff! THANK YOU SO MUCH!
(BTW, love the time is an illusion part)
I have created a similar script myself, but mine did not have to be constantly running in a shell the entire time. Instead, it uses svchost to schedule task.
What I did, was use the "AT" command, which you can use to schedule a task (such as another batch script) to run at a certain time, day, and how often to run it.
However, Administrator privileges are required to use the "AT" command.
For syntax, just type "AT /?" in a console.
lemonie6 years ago
Can you use a greater than function? and what does that do?
L
XOIIO (author) 6 years ago
That might help, but for some reason it shows something like this.
01:12:56.45’ ’==‘00:18:05.20’ was not expected at this time.
When I put it in like this
IF 'TIME'=='02:57:00.00' (GOTO yes) ELSE (GOTO LOOP)
is stays open and echoes waiting --part of the script-- but when the time changed it didn't help.
