Will this 555 circuit for 8 leds flashing work?
Will this 555 timer work and make these 8 leds flash with this circuit I drew up.
Picture of Will this 555 circuit for 8 leds flashing work?
A couple more notes:
Those LEDs are rated at only 30 mA continuous, whereas this circuit runs them at around 50 mA. Not a problem for a low duty cycle with short pulses, but this circuit as you intend has a high duty cycle. Where you might run into a problem is that you're right at the maximum capacity of the output pin (200 mA). You might want to have the output pin drive a transistor to source the LED current.
With the resistors you've selected, the LEDs will be on about half the time, and flashing a bit over once per second. This is why Rick recommends something more like a 1MOhm resistor, to slow the pulse rate down. What I would recommend is that you replace the 470 KOhm with a 1 MOhm and then put a diode across it. This allows the cap to charge only through the 1K resistor, resulting in a very quick flash, followed by a relatively longer off period as the capacitor is forced to discharge through the 1M resistor. You should, of course, play around with the resistor values until you find a flash that is what you want,
Good luck!
rickharris4 years ago
output for the 555 is pin 3 not pin 2
Capacitor should go to ground.
5 should have a small cap to ground.
didn't check the value but the 1 K looks small I might expect something closer to 1 Meg ohm and 47 K rather then 1 K and 470K
mykiscool (author)  rickharris4 years ago
Ok, thanks I'll fix those changes. Like they always say, measure twice cut once. Glad I didn't go ahead before verifying and ruin my 555/led.
iceng4 years ago
+1 Rick
