Will this schematic work/ Is it right?
I know the wiring for the loops themselves are correct but I am wondering if I did the master bypass and LEDs correctly.
This is a 5 channel/ loop switcher for guitar or audio effects loops, The master bypass is supposed to negate the other loops even if they are on.
Thanks for the help!
P.S. the squares with the 9 dots are all 3pdt switches
Picture of Will this schematic work/ Is it right?
Can't tell what is going on here. Look up the appropriate schematic notation for the switches and try your drawing again.
beardedknome (author)  mpilchfamily4 years ago
Honesty, I have no idea how to use 3pdt notation and non of the free schematic designers I downloaded even had them.
However I do have the schematic it was based on... http://3.bp.blogspot.com/-fKnJMW7x0nw/T_tiZXAGKGI/AAAAAAAAB18/16AsBt2JKMY/s1600/TB+Looper+5+with+buffer+and+tuner.png
At the very least a picture of the switches in question and the current wiring could go a long way.
I didn't start wiring it yet because I wanted to make sure I was correct, this is a diagram of the switches, the difference is the switches on the schematic are rotated 90 degrees
Also the pins run perpendicular to the floor if you were holding the switch in front of you, the connections run from middle to left and middle to right
+1
