Wireless water level indicator?
I have a tank that's above my 2 story house. I did use a 50 foot Ethernet cable and wire up a level indicator, with 5 levels from empty to full. But the wires always corroded, and it just stopped working. What i'am looking for is a way, to do the same wirelessly. Maybe even automate via ifttt, as my motor is connected to a smart plug the HS100. How can i accomplish this, the tank is open to the elements, so something waterproof, and solar/battery operated would be great. I did think of the Xiaomi Water sensor, which generally checks for dampness,but that needs a Xiaomi gateway, so what does the community suggest?
ggom2017 days ago
Hello!
Your previous system looks great, with it' 5 levels of measurment.
Think about electronics in a submarine .
Why not try a sealed plastic enclosure for those connections.
They are easy to find , not expensive at all.
When finished and tested the system,
seal it at cable bypasses, cover, screws, everywhere with a
silicon sealer, you can also put in some silica-gel in a little container
that will absorb any residual moisture.
Regards
rickharris19 days ago
Entire hoast of the available at very little cost. You unlikely to be able to DIY for less
https://www.amazon.co.uk/Smanos-Wireless-Water-Sen...
