Would a stripped (backlight-removed) LCD pass IR light through?
http://www.engadget.com/2006/10/17/how-to-build-your-own-hd-projector-part-1/
underneath an IR display like this:
http://www.instructables.com/id/Interactive-Multitouch-Display/
Beneath it all, I would put an IR converted webcam & a lamp. The goal is to make it as compact as possible under the desk.
This design hinges upon the IR light from the touch screen passing through the stripped LCD.
Thoughts?
7
answers
Answer it!
My question is "how are you going to read the touch location and translate that into coordinates?".
The reason I ask this question is because, AFAIK, LCD's work by blocking the backlight in controlled manner, right?
YOu need to test it when the screen is clear and when the pixels are turned on. When turned on they may well block ir.
