answers
Answer it!
Look at this site it will explain how the circuit works. (Don't copy the circuit off that site you will get a voltage way higher than what you need, reduced duty cycle on the sites circuit would fix that problem).
Other than that the TC circuit looks fine. (Maybe I wouldn't ground the TC to my circuit).
coil with isolating inductors feeding energy to the spark gap.
- The NPN 2N3055
- VCBO = 100V not very encouraging
- Ic = 15A
- IB = 7A
- Hfe = 20min 70 max DC gain may be more @ lower gate drive
- Means only saturate 6A @ 20Hfe and possibly 15A @ 70Hfe
- Because a 555 can deliver 300ma
- Power dissipation = 115W with huge heat sink.
- I don't see kickback protection for the power NPN
- Or a 470uF across the source 12VDC power.
- The door bell is a poor switch.
- I would tie the ignition coil ahead of the bell switch.
- And move the ground connect to the NPN emitter to avoid upsetting the 555 with a ground loop.
Is there a precedent for that design of HV driver?
What coil structures, chokes, capacitors and SG do you propose to use?
L
