Yaesu FT-290R internal battery power?
I've put in 8 new Cs, correct polarity.
I've looked at a .PDF of the owner's manual online, no help there.
Any ideas? I really want to get into SOTA and WOTA, but with no portable PS I can't.... :-(
By the way, my callsign is M6AIM, mike, six, alpha, india, mike.
12
answers
Answer it!
I'll take a wild guess and suggest the switch that switches between external PSU and battery, and which is usually inside the connector for the external supply is damaged - should be an easy fix.
Steve
Thanks BTW :-)
Here's a link to the manual if you don't have one.
I cant even turn it on (power it) with the battery. That's my problem. :-D
The 'V' shape on the end of the switch, next to the black up arrow is lifted AS you plug in the DC. It DISCONNECTS the batteries as you do so. IF that switch is faulty, it is JAMMED OFF, and even when the plug is removed the switch DOESN'T let the batteries work.
