Zenith 68-7 Bendix Carb Help?
I have been working on my Wisconsin AENL engine for a project (A bike or now I am thinking maybe a racing lawnmower) and I had it running since I re-built it, however, it was running a bit off, so I cleaned the carb. Afterward it wouldn't run. I did not adjust any of the settings on it, and I can put gas in through the spark plug hole and it fires, so I am sure it is the carb. I have since moved the settings (Idle and high speed jet) to see what would happen, but I have kept note of where they were set. Usually I have no problem fixing engines, however, I don't have as much experience with these engines or there carbs and thought it a good idea to seek some help before proceeding.
Thanks
15
answers
Answer it!
Good luck,
Qa
Yes I have tried both the, "Megachoke" method, as well as adjusting everything to the lowest settings (Idle and Main Jet), with no choke and have got similar results from both, 1/10 pulls it will fire once, but won't take off. I have very thoughrly gone through and cleaned the orifices in this carb when I rebuilt it. Everything is open, I know that much, have done major checks on everything before it went back together. This is why it seems so odd it all of a sudden will not run, everything is clean and clear, abut no matter how it's adjusted, nothing. I have tried every combination of settings for what can be adjusted, all three levels of octane fuel, and tried all in combination with each other along with combinations of choke and throttle. For everything I tried the choke in three positions, on, off, and half, as well as the throttle set to 5 different settings from idle, to full throttle. This seems very bizarre.
1.) There is a massive air gap somewhere between the engine and the fuel tank that doesn't allow the pressure differential to pull fuel into the carb.
2.) The fuel pickup is either loose, missing, clogged or jammed in so tight that fuel is prevented from entering the carb. If it is fed from a "remote" tank, is the fuel valve in the "ON" position? Air blocking the line (possible, but not probable - gotta ask anyway)? Hose kinked?
There is a third possibilty that ALWAYS reminds me of Slingblade - got any gas in the tank?
As an addendum / follow up on my last post, did you pour any gas into the carb to prime it?
These engines are so simplistic that this should be all you need to get it running. If it still doesn't run, you should pull the whole fuel system (carb to tank) off and start again, piece by piece.
Qa
Thank you
Hey Wesley666, did you have the engine completely apart? I ask because I want to know if the intake valve is opening and closing. Most importantly is it opening? To find out without pulling it apart at the case, take off the carb and get someone to pull the starter rope while you put your hand near the intake hole. You should feel suction, but no blowback. If you don't feel anything or it is reversed, (blowback but no suction) then you have a cam or valve problem.
Just throwing it out for consideration...
Qa
Something that was discovered by Harley Davidson with regards to gas (their engines can't tolerate high levels of ethanol) was that sometimes people were inadvertently getting a lot more of it than they were supposed to. On the multi-fuel pumps if you use a nozzle that someone just used for HighTest a lot of that fuel remains in the hose. So these motorcycles were getting big doses of ethanol that was left in the pump from the previous purchase. Since motorcycle fuel purchases are usually small, unlike cars, it didn't get diluted with regular gas as much. So, when you buy fuel try and get a pump that is for just one kind of gas or use a pump that someone just used for the type of gas that you want.
What did you use to clean it? Some cleaning fluids leave stuff on the surface, which may make parts stick.
Roughly what is inside that carb? do you have any pictures of the internals, or a link to the manual?
For a quick fix, try passing some clean fuel or carb cleaner trough the fuel input and jet, to make sure it is clear.
If there is a piston like part, ensure it slides up and down freely under its own weight, or under the force of the return spring.
