a 12/6vdc gen. motor with the outer casing that rotates and the center armature as a fixed part to a frame?
I want to use a 12/6vdc motor that will generate its own renewable power to be stored in batteries.  I want to use a small motor where the outer casing will rotate and the armature will act as a fixed support to a frame. However a small outside diameter is an issue, so it should not exceed 2inches. Is this possible????? I could go another way with gears but I am trying to develop a unique  propulsion method
rickharris4 years ago
You can't drive a motor from a battery and use that same motor to recharge the battery? or do I not understand your aim/
You appear to be talking about a brushless outrunner type motor - Look at a few RC hobby sites to see what is available.
jaysashanewt (author) 3 years ago
Actually that was my hope to see if such a thing exists....I guess I was dreaming to find such a concept
caarntedd3 years ago
Ceiling fan?
iceng4 years ago
Inside out electric machines are old hat !
Long skinny machines are used where a low inertia ( easy Acceleration / Deceleration ) is
a desirable trait like a sawmill set-works compared to a high torque large diameter
automotive machine.
Although the successful Tesla electric car uses a small diameter Non-PM Induction motor
for efficiency and out performs a comparable BMW...
jaysashanewt (author)  iceng3 years ago
Thank you for the information, I was able to look on the internet to see what was available in that style of motor, now I need to reengineer my idea
thanks again
iceng iceng4 years ago
BTW batteries are not efficient !
For example a lead acid car battery will only return half of the
energy used to charge it...
My concept is to have a dc motor where the armature is fixed so I can attach to the stator and use it for a wheel axle plus the movement will create dc voltage which will charge a battery pack
How tiny do you want to go.
Take a CD drive apart and check out the motor that spins the CD. With a little rewiring that will do what you want.
Joe
