a led and a pot that controlls an 8 leds whrein the last state of the pot will be the starting point of the push buton?
AmenolaS (author) 8 days ago
any additional idea . thanks
You have the answer
RIGHT. With a decent description we can help !
Here's something which you'll need to modify a bit to get exactly what you want, its not in Arduino code, but you should get a rough idea.
loop()
//Read analog voltage (ANIN):
Meas=map(ANIN,0,1024,0,7);
if (Pushctr>MEAS)
{Meas=Meas+pushctr};
//turn all leds off at start of testing loop with some little subroutine - call it alloff;
alloff;
if (meas=0) led1=TRUE;
if (meas=1) led2=TRUE;
if (meas=2) led3=TRUE;
if (meas=3) led4=TRUE;
if (meas=4) led5=TRUE;
if (meas=5) led6=TRUE;
if (meas=6) led7=TRUE;
if (meas=7) led8=TRUE;
if (pushbutton =TRUE)
{pushcounter++;
if (pushcounter>8) pushcounter=0;
WHILE (pushbutton=TRUE) {}
You aren't making sense at all, so we can't help
AmenolaS (author)  steveastrouk9 days ago
sorry, its just it kills me. I have the code for both of them but when i try to combine them, it doesnt work as i want it to be.
AmenolaS (author)  AmenolaS9 days ago
heres the code and i dont know what to put in the loop part.
const int buttonPin = 2;
const int analogPin = A0;
const int ledPin1 =3;
const int ledPin2 = 4;
const int ledPin3 = 5;
const int ledPin4 =6;
const int ledPin5 = 7;
const int ledPin6 = 8;
const int ledPin7 =9;
const int ledPin8 = 10;
int buttonState = 0; // variable for reading the pushbutton status
int buttonPressCount = 0;
int numberOfLED = 5;
int analogValue=0;
void setup() {
// put your setup code here, to run once:
pinMode (ledPin1, OUTPUT);
pinMode (ledPin2, OUTPUT);
pinMode (ledPin3, OUTPUT);
pinMode (ledPin4, OUTPUT);
pc);
pinMode(analogPin, INPUT);
pinMode(buttonPin, INPUT);
Serial.begin(9600);
void loop() {
// put your main code here, to run repeatedly:
void potFunction(){
analogValue = analogRead(analogPin);
if(analogValue <128){
digitalWrite(ledPin1,HIGH);
digitalWrite(ledPin2,LOW);
digitalWrite(ledPin3,LOW);
digitalWrite(ledPin4,LOW);
digitalWrite(ledPin5,LOW);
digitalWrite(ledPin6,LOW);
digitalWrite(ledPin7,LOW);
digitalWrite(ledPin8,LOW);}
else if(analogValue >128 && analogValue <256){
digitalWrite(ledPin1,LOW);
digitalWrite(ledPin2,HIGH);
else if(analogValue >256 && analogValue <384){
digitalWrite(ledPin3,HIGH);
else if(analogValue >384 && analogValue <512){
digitalWrite(ledPin4,HIGH);
else if(analogValue <512 && analogValue >640) {
digitalWrite(ledPin5,HIGH);
else if(analogValue > 640 && analogValue <768) {
digitalWrite(ledPin6,HIGH);
else if(analogValue >768 && analogValue <896) {
digitalWrite(ledPin7,HIGH);
else{
digitalWrite(ledPin8,HIGH); }
Serial.println(analogValue);
delay(1);
void buttonFunction(){
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
if (buttonPressCount % numberOfLED == 0) {
digitalWrite(ledPin1, HIGH);
} else {
digitalWrite(ledPin1, LOW);
if (buttonPressCount % numberOfLED == 1) {
// turn LED1 on:
digitalWrite(ledPin2, HIGH);
} else {
digitalWrite(ledPin2, LOW);
if (buttonPressCount % numberOfLED == 2) {
digitalWrite(ledPin3, HIGH);
} else {
digitalWrite(ledPin3, LOW);
if (buttonPressCount % numberOfLED == 3) {
digitalWrite(ledPin4, HIGH);
} else {
digitalWrite(ledPin4, LOW);
if (buttonPressCount % numberOfLED == 4) {
digitalWrite(ledPin5, HIGH);
else {
digitalWrite(ledPin5, LOW);
if (buttonPressCount % numberOfLED == 5) {
digitalWrite(ledPin6, HIGH);
} else {
digitalWrite(ledPin6, LOW);
if (buttonPressCount % numberOfLED == 6) {
digitalWrite(ledPin7, HIGH);
} else {
digitalWrite(ledPin7, LOW);
if (buttonPressCount % numberOfLED == 7) {
digitalWrite(ledPin8, HIGH);
} else {
digitalWrite(ledPin8, LOW);
buttonPressCount++;
delay(400);
iceng11 days ago
Could you be calling the microprocessor == uP a "pot" ?
Because a pot is short for potentiometer which is a manually variable resistor..
And if it is a pot what does it used for
A] dimming the LED light ?
B] changing the speed ?
C] or tell us what...
AmenolaS (author)  iceng10 days ago
no a potentioimeter and a push button that
iceng AmenolaS9 days ago
BUT What Do YOU Want to Happen When YOU Turn the POT ????
AmenolaS (author)  iceng9 days ago
when i turn the pot at a specific range such as analogValue<128 ,the first led lit and as i increases the range the next led lit and so on. the push button here acts as another input such as, as a push it the last state of the pot will be its starting point and as a push it again it lit the next led and so on. it goes by as i change the pot or the push button. tahnks
A potentiometr and a push button that controlls an 8 leds. pot here acts as a controller for the lighting of the led such as when at spicific range , one of the leds light and as the range increases it goes to the next led. As for the push button, the last state for the pot will be its starting point and it goes as i push the button to the next led. thank you
AmenolaS (author) 9 days ago
A potentiometr and a push button that controlls an 8 leds. pot here acts as a controller for the lighting of the led such as when at spicific range , one of the leds light and as the range increases it goes to the next led. As for the push button, the last state for the pot will be its staring point and it goes as i push the button to the next led. thank you
rickharris11 days ago
Broken
I know a good refurbish and polish service for damaged globes that are injured by some crazy thinking members asking impossible to mind read questions over and over ;-)
