3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
a simple electric component that acts like a spark gap?
is there a simple electric component that acts like a spark gap? something that will not conduct until a voltage is reached? i would like to replace the inefficient spark gap in the Tesla coil. also, also voltage needs to be very precise, the breakdown voltage across a gap varies for a clean oscillation. then, the coil should be less noisy.
Dec 27, 2011. 1:53 PMfreenergyfuture says:
i have just barely read the responses, but i need to know if there is any device that will provide a high frequency spark gap powered by 1.5v? I desire to harness and experiment with cold electricity, but first i must be able to use CE.
Dec 28, 2011. 10:39 AMfreenergyfuture says:
unfortunately i am a beginner when it comes to electronic circuits, i have researched joule thieves and decided they are the best i can utilize, combined with the FLEET design's. how long would it take for AA to power a 250v 2.7uf(i think, the prints a little hard to read) capacitor? i also have 6 10v 2200uf & 6 10v 1000uf caps. 20 2n3904 transistors & 5 sets of 5 vari resistors @ 100ohm, 1k, 10k, 100k, &500k. using a 1.5'' pvc as toroid.
other research includes most of www.free-energy-info.co.uk/ chpt. 5. is FLEET JT's
Dec 28, 2011. 11:45 AMfreenergyfuture says:
you can learn more about FLEET by going to chapter 5 of the website and using ctrl-F to find it under joule thief. i am using a pvc because that is all that i have available and is what a FLEET uses. is there a way of combining several 2n3904's together to increase the frequency? i have read; by using high frequency and high voltage through a spark gap, cold electricity is produced. CE flows on the outside of a wire rather then through it. i have read and seen on youtube several JT's that are able to charge other batteries.
Dec 28, 2011. 1:05 PMfreenergyfuture says:
would a marx generator be useful in effecting CE? http://www.youtube.com/watch?v=jHGK1trR9mg&feature=related
this is a don smith circuit for a tesla coil, would routing the JT through it be useful for CE? any info on CE via the most simple manner will be of great help.
Dec 30, 2011. 10:42 PMfreenergyfuture says:
As I stated, information I've gathered states, a high frequency high voltage spark gap will cause Cold Electricity. It is the exact opposite of regular Electricity, a pure form of electricity. the more power used by it the colder the item becomes. as for the Dom Smith circuit, it appears that it can increase dc via the pulsing; what I need is to know exactly how it works. Before I am willing to put anything together I must first learn all I can about it in order to not make costly mistakes.
Aug 4, 2011. 9:40 AMorksecurity says:
Random thought: A NE2 neon bulb is a spark gap of sorts. Probably not at the breakdown voltage you want, though. (I wonder what stacking several in series would do.)
Aug 5, 2011. 8:57 AMorksecurity says:
In that case, I think the answer is "make a spark gap". I know that isn't the answer you wanted.
Aug 1, 2011. 3:30 PMorksecurity says:
I haven't looked at them in any detail, but by my understanding MOVs would *not* give you the desired response.
*Any* current surge is going to lose some power to heat and EM radiation.
Aug 2, 2011. 9:32 PMorksecurity says:
Metal Oxide Varistor. The component used in most consumer surge suppressors.
Jul 31, 2011. 7:46 AMsteveastrouk says:
If the gap is well made, and the electrodes polished, a spark gap is a remarkably clean HT switch
Steve
Jul 31, 2011. 8:51 AMsteveastrouk says:
And you think any real semiconductor switch has a lower loss do you ?
Jul 31, 2011. 9:29 AMsteveastrouk says:
So enclose your airgap, put it in a nice atmosphere controlled enclosure.
Jul 31, 2011. 12:41 PMsteveastrouk says:
Not if its designed properly it won't
Jul 31, 2011. 9:08 AMsteveastrouk says:
Clearly.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
