accumulator # immediate data ?
hello ,
What I need to know  if I want to load the immediate value  into the accumulator
accumulator is  8 bit, assume  address of accumulator is  11 10 01 01
temporary register is  8 bit  that hold Immediate data 00 00 00 11
Instruction register
example
LD A, # 00 00 00 11
this is 2 byte instruction
first  byte is 11 10 01 01
second byte is 00 00 00 11
lets assume that first byte is opcode , store into instruction register  This is the first instruction fetch cycle.
fetch , decode , and execute
how to decode and execute the first byte instruction
iceng3 years ago
Accumulators have a designation code and a load immediate is a code based on the ML for that function with an 8 bit immediate value.
You may want to study micro language.
iceng3 years ago
You are missing some key knowledge about processors....
They, all the processors you know of, excepting neural networks, are clocked ( made to step advance ) for an orderly sequence of data flow.
Once you understand clocked memory and data signals, then you will begin to"understand how to make common data bus."
Some older processors used the same bus for both the data and for memory clocked address.
Other processors use a separate clocked memory data bus and address bus.
A lot of these concepts are discussed by Markus
http://wandel.ca/homepage/mc68008/
Good reading....
vead (author) 3 years ago
hello,
I made three diagram. I don't understand how to make common data bus
first diagram show the CPU register and Memory
In second diagram ,cpu register read data from memory
