loading
add more leds?
dear Becky the sketch compile and work fine with the exemption of the last led who light dim
I suspect a wrong resistor value, no was good a bad led,no was good ,change to another pin ,no luck
make a slow delay and measure the volts out ,on the first four 4,8 on the last just 1.7 ,no errors nothing wrong even change boards
int d = 1500;
void setup(){
for (int led = 6; led < 10; led++){ //set pins 6 to 10 as output
pinMode(led,OUTPUT);
void loop(){
for (int led=6; led < 10; led++){ // loop go up
digitalWrite(led, HIGH );
delay (d);
digitalWrite(led,LOW);
for (int led = 10;led > 6;led--){ //loop go down
digitalWrite(led,HIGH);
delay (d);
bekathwia2 months ago
A dim LED with no other symptoms is usually a failure to declare that pin as an output at the start. Take a look at the bounds of your for loops-- you set pins 6, 7, 8, and 9 as outputs in the setup, but later on your decrementing for loop starts at 10. play around with those numbers and remember that < and <= mean two different things!
