loading
adjustments for altitude?
Audrey,
I have just started your course and so far find the instructions very helpful. I have not yet attempted this first loaf since I live at a higher altitude in Denver. I know altitude affects cooking times because water boils at a lower temperature due to the decrease in atmospheric pressure. I would guess that the heat transfer is also lower due to the decrease in the density of the air. Do you have any experience with adjusting baking procedures for higher altitudes? Also, Denver is a fairly dry climate. Are there any changes I will have to make due to the decrease in humidity?
Thanks in advance! Can't wait to try it out!
-Tristen
audreyobscura3 months ago
I was living in Reno when I first started baking bread, and boy do I miss the high desert landscape, but do not at all miss the baking pickle you are in. I would increase your baking temperature by ~25 degrees and increase your water by 5-10% You may have some super wet doughs, so you may have to knead your bread in a bowl, or check out the stretch'n'fold method outlined in the sourdough lesson.
It will take a little bit of experimentation to nail the recipe, but I promise, each of your experiment iterations will be delicious.
