sprinkler valve and blow gun valve?
answer
Answer it!
Most sprinkler valves used for spud guns are electronically operated. The valve I previously mentioned has two wires going into the solenoid(its the large black on the valve) for you two hook up to your power source and switch. For that you will need 3 9 volt batteries wired together and then a switch then back to the solenoid wires. I am not 100% sure if that is how you do it as I always use a blowgun for my valves.
Last the blowgun modification to the sprinkler valve is not necessary at all. It is simply a different way of triggering the sprinkler than electorally. BUT the blowgun modification is, in my opinion, much better and much easier than wiring it. Using a blowgun has some perks and disadvantages. It is much better because it opens the sprinkler 3-5 times faster than using wires and such. In spud gun world that is a big differnence is valve speed and very good for your gun. The only disadvantage is that you will drill have to drill a hole in the valve for your blowgun and once you drill the hole you can not undo it and if you have messed up the valve may be ruined. The perks outweigh the disadvantages as it is very easy to drill the hole in the sprinkler and screwing up the sprinkler while doing this is rare.
If you have any further question just ask or PM me,
Ostomesto
