3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
anyone know if an dc motor from a electric scooter /wheelchair will work as generator ?blackpool.99@hotmail.com
null
May 21, 2010. 12:19 PMpetercd says:
the important thing to remember about DC motors when trying to run them as a generator, is what the working rpms of the particular motor are.
eg my 12v dc air horn compressor is rated at about 2000rpm, totally useless for a wind turbine because theres no way Im gonna spin a 6ft blade at 2000rpm.
Ideally you would use a low rpm motor <500rpm without a gearbox, it must be direct drive, the gearbox will add too much drag to make it a viable proposition for DIY  use.
So to answer your question, yes it will produce as a generator but at what revs, 1500rpm's? then the question becomes, what method are you going to use to spin it at its working revs?
Jun 18, 2009. 4:08 PMRob Patterson says:
Yes as long as it's a permanent magnet motor and you run it "backwards" it will produce usable electricity.
Mar 29, 2009. 2:04 PMNachoMahma says:
. Most DC motors can be used as generators.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
