assembly program
I have pic12f675. i have the neccessary asm and the header files.but i cannot compile it.
please can you send me the hex file after compiling the program?
as iam a student of class 8, idon't know how to compile. can you also send me the required steps?
The required files are posted
;;LED FX.asm
;  11-3-2010
list p=12F629
radix dec
include "p12f629.inc"
  errorlevel -302 ; Dont complain about BANK 1 Registers during assembly
__CONFIG _MCLRE_OFF & _CP_OFF & _WDT_OFF & _INTRC_OSC_NOCLKOUT  ;Internal osc.
;_MCLRE_OFF  - master clear must be off for gp3 to work as input pin
; variables - names and files
temp1  equ 20h ;
temp2  equ 21h ;
temp3  equ 22h ;
temp4  equ 23h ;
jump  equ 24h ;jump value for table1
fadeUp  equ 25h
fadeDwn  equ 26h
sequences equ 27h
sw_duration equ 28h
testing  equ 29h
;Equates
status  equ 0x03
rp1   equ 0x06
rp0   equ 0x05
GPIO   equ 0x05
status  equ 03h
option_reg equ 81h
  ; bits on GPIO
pin7  equ 0 ;GP0  LED C
pin6   equ 1 ;GP1  LED B
pin5  equ 2 ;GP2  LED A
pin4  equ 3 ;GP3  Sw A
pin3  equ 4 ;GP4  Sw B
pin2  equ 5 ;GP5  Sw C
  ;bits
rp0   equ 5   ;bit 5 of the status register
;Beginning of program
  org  0x00
  nop
  nop
  nop
  nop
  nop
SetUp bsf  status, rp0  ;Bank 1
        movlw b'11111000'  ;Set TRIS  GP0,1,2 out   GP3,4,5 input
  movwf TRISIO         ;
  bcf  status, rp0  ;bank 0
  movlw   07h          ;turn off Comparator ports
        movwf   CMCON        ;must be placed in bank 0
  clrf  GPIO         ;Clear GPIO of junk
  call _memory
  btfss gpio,5   ;SwA to: "record new sequence"
  goto record
  btfsc gpio,3  ;SwC removes attract sequence
  goto $+.10
  movlw 0FFh
  bsf  status,rp0 ;select bank1
  movwf EEDATA
  bcf  status,rp0 ;select bank0
  movlw .101
  movwf EEADR
  call  write
  movlw .101
  bsf  status,rp0
  movwf EEADR
  bsf  EECON1,0 ;starts EEPROM read operation storing result in EEDATA
  movf EEDATA,w ;move read data into w
  bcf  status,rp0
  xorlw .8   ;look for 8 - for Attract mode
  btfsc 03,2
  goto Attract_Seq ;selected sequence will appear first
  goto  Main
;* Tables    *
table1 addwf   PCL,F           ;02h,1  add W to program counter
  retlw   .10     ;
  retlw   .50
        retlw   .30     ;
  retlw   .50
  retlw   .100     ;
  retlw   .40  ; program starts at bottom of table
  retlw   .10     ;
  retlw   .50
        retlw   .30     ;
  retlw   .50
  retlw   .60     ;
  retlw   .10     ;
  retlw   .50
        retlw   .10     ;
  retlw   .50
  retlw   .100     ;
  retlw   .20     ;
  retlw   .50
        retlw   .30     ;
  retlw   .50
  retlw   .70
  retlw   .60     ;
  retlw   .100     ;
  retlw   .50
        retlw   .100     ;
  retlw   .50
  retlw   .100     ;
  retlw   .70     ;
  retlw   .50
        retlw   .30     ;
  retlw   .50
  retlw   .70     ;
table2 addwf   PCL,F           ;02h,1  add W to program counter
  goto seq1
  goto seq2
  goto seq3
  goto seq4
  goto seq5
  goto seq6
  goto seq7
  goto seq8
  goto seq9
  goto seq10
  goto seq11
  goto seq12
;* Delays    *
_xuS movwf temp2
_uS  movlw .10
  movwf temp1
  decfsz temp1,f
  goto $-1
  decfsz  temp2,f
  goto  _uS
  retlw  00
_ZuS movwf temp2
  goto $+2
  goto $+2
  decfsz  temp2,f
  goto  $-3
  retlw  00
_xmS movwf temp2
_x  nop
  decfsz  temp1,f
  goto  _x
  decfsz  temp2,f
  goto  _x
  retlw  00
  ;5mS delay for increments in timing for "New Sequence"
_5mS movlw 05h
  movwf temp2
_5  nop
  decfsz  temp1,f
  goto  _5
  decfsz  temp2,f
  goto  _5
  retlw  00
_10mS movlw 0Ah
  movwf temp2
_10  nop
  decfsz  temp1,f
  goto  _10
  decfsz  temp2,f
  goto  _10
  retlw  00
_50mS movlw .50
  movwf temp2
_50  nop
  decfsz  temp1,f
  goto  _50
  decfsz  temp2,f
  goto  _50
  retlw  00
_100mS movlw .100
  movwf temp2
_100 nop
  decfsz  temp1,f
  goto  _100
  decfsz  temp2,f
  goto  _100
  retlw  00
_150mS movlw .150
  movwf temp2
_150 nop
  decfsz  temp1,f
  goto  _150
  decfsz  temp2,f
  goto  _150
  retlw  00
;* Sub Routines    *
_memory
  movlw .48
  movwf temp1
  movlw 2Fh
  movwf fsr
  incf fsr,f
  movlw 0FFh
  movwf indf
  decfsz temp1,f
  goto $-4
  retlw 00
     ;SwB puts current sequence into EEPROM for turn on.
     ;and puts "marker" in location 101
Attract
  movf sequences,w ;put sequence number into w
  movwf EEDATA
  movlw .100
  movwf EEADR
  call  write
  movlw .8
  movwf EEDATA
  incf EEADR,1
  call  write
  nop
  goto $-1   ;Project must be turned off
  ;Seq selected as Attract will be displayed when project turned on
Attract_Seq
  movlw .100
  bsf  status,rp0
  movwf EEADR
  bsf  EECON1,0 ;starts EEPROM read operation. Result in EEDATA
  bcf  status,rp0
  movwf temp4
  movf temp4,w
  call table2
  goto $-2
  ;record new sequence - looks for "no switch pressed" for 1.25 seconds to exit
  ;uses files 30h to 5Fh  (48 files)
  ;three files per "step"   1st file = LEDs,  2nd = Off time, 3rd = on time
  ;15 steps allowed - look for 5Dh
record btfss gpio,5  ;wait for release of button A
  goto $-1
  movlw 30h
  movwf fsr   ;start storage at file 30h
   ;look at keys being pressed - identifies 2 or 3 keys pressed together
_r1  clrf sw_duration
_r1a call _5mS
  incfsz sw_duration,1  ;5mS x 256 = 1.25seconds
  goto $+2
  goto Store  ;time out! store files 30h to 5Fh in EEPROM
  btfss gpio,5  ;see if one or more Sw is pressed
  goto $+5
  btfss gpio,4
  goto $+3
  btfsc gpio,3
  goto _r1a  ;no sw pressed create 2.5 sec timing
       ;1,2,or 3 sw pressed
  call _10mS  ;delay to detect 2 or 3 switches
  goto $+2
  goto Main
  btfsc gpio,5  ;SwA
  goto $+2
  bsf  gpio,0  ;turn on LED A
  btfsc gpio,4  ;SwB
  goto $+2
  bsf  gpio,1  ;turn on LED B
  btfsc gpio,3  ;SwC
  goto $+2   ;
  bsf  gpio,2  ;turn on LED C
       ;LEDs have been illuminated
  movf gpio,w
  movwf indf   ;w moved to fsr's file (30h+)
  incf fsr,f
  movf sw_duration,w ;off time!!
  incf fsr,f
  clrf sw_duration
_r2  call _5mS
  goto $+2
  goto record  ;time out! keys pressed too long. Start again
  btfss gpio,5
  goto _r2   ;sw pressed
  btfss gpio,4
  btfss gpio,3
       ;file empty. Put duration into file
  movf sw_duration,w ;on time
  incf fsr,f
  movlw 5Dh
  xorwf fsr,w
  btfss 03,2
  goto $+2
  goto Store  ;stop at 15 steps. store files 30h to 5Fh in EEPROM
  clrf gpio
  goto _r1
   ;sequences:
   ;seq1 Self-Programmed sequence
   ;1St file:LEDs  2nd file:OFF time  3rd file:On time
seq1 bsf  status,rp0
  clrf EEADR
  bcf  status,rp0
  bsf  status,rp0
  bcf  status,rp0
  movwf gpio
  bsf  status,rp0
  incf EEADR,1
  bsf  EECON1,0 ;
  bcf  status,rp0
  movwf temp4 ;this is OFF time. Store it
  bsf  status,rp0
  incf EEADR,1
  bsf  EECON1,0 ;
  bcf  status,rp0
  movwf sw_duration ;this is ON time
  call _5mS
  decfsz sw_duration,1
  goto $-2
  clrf gpio
  call _5mS
  decfsz temp4,f ;create OFF duration
  goto $-2
  bsf  status,rp0
  incf EEADR,1
  bsf  EECON1,0 ;
  bcf  status,rp0
  xorlw 0FFh ;look for 0FFh - end of routine
  btfss 03,2
  goto $-31
  retlw 00
   ;seq2  chase right - very fast
seq2 bsf  gpio,0
  call _100mS
  bcf  gpio,0
  bsf  gpio,1
  call _100mS
  bcf  gpio,1
  bsf  gpio,2
  call _100mS
  bcf  gpio,2
  call _100mS
  clrf gpio
  retlw 00
  ;seq3  chase right
seq3 bsf  gpio,0
  call _150mS
  bcf  gpio,0
  bsf  gpio,1
  call _150mS
  bcf  gpio,1
  bsf  gpio,2
  call _150mS
  bcf  gpio,2
  call _150mS
  clrf gpio
  retlw 00
  ;seq4  chase right with off-delay at end
seq4 bsf  gpio,0
  call _150mS
  bcf  gpio,0
  bsf  gpio,1
  call _150mS
  bcf  gpio,1
  bsf  gpio,2
  call _150mS
  bcf  gpio,2
  call _150mS
  retlw 00
  ;seq5  left right left right
seq5 bsf  gpio,0
  call _150mS
  bcf  gpio,0
  bsf  gpio,2
  call _150mS
  bcf  gpio,2
  retlw 00
  ;seq6  middle on   middle off
seq6 bsf  gpio,1
  call _150mS
  bcf  gpio,1
  call _150mS
  clrf gpio
  retlw 00
  ;seq7  All on   all off
seq7 clrf gpio
  call _150mS
  decf gpio,f
  call _150mS
  clrf gpio
  retlw 00
seq8 ;seq8  middle on then sides on
  bsf  gpio,1
  call _150mS
  bcf  gpio,1
  bsf  gpio,0
  bsf  gpio,2
  call _150mS
  clrf gpio
  retlw 00
  ;seq9  police flasher  3 times left 3 times right
seq9 bsf  gpio,0
  call _50mS
  bcf  gpio,0
  call _50mS
  bsf  gpio,0
  call _50mS
  bcf  gpio,0
  call _50mS
  bsf  gpio,0
  call _50mS
  bcf  gpio,0
  call _50mS
  bsf  gpio,2
  call _50mS
  bcf  gpio,2
  call _50mS
  bsf  gpio,2
  call _50mS
  bcf  gpio,2
  call _50mS
  bsf  gpio,2
  call _50mS
  bcf  gpio,2
  clrf gpio
  call _50mS
  retlw 00
  ;seq10  random flicker
seq10 movlw .32  ;start at bottom of table
  movwf jump
  bsf  gpio,1
  movf jump,w ;put table jump value into w
  call  table1
  call _xmS
  bcf  gpio,1
  decfsz jump,f
  goto $+2
  retlw 00  ;top of table found
  call  table1
  call _xmS
  goto $-11
  ;seq11  slow fade up down
seq11 clrf fadeUp  ;
  clrf fadeDwn
  incf fadeUp,f ;to create 1 (delay routine does not like 00)
  bsf  gpio,1
  movf fadeUp,w
  call _xuS
  bcf  gpio,1
  movf fadeDwn,w
  call _xuS
  decfsz fadeDwn,f ;
  goto $-8
  incf fadeDwn,f ;to produce 1
  bsf  gpio,1
  movf fadeUp,w
  call _xuS
  bcf  gpio,1
  movf fadeDwn,w
  call _xuS
  decf fadeUp,f
  incfsz fadeDwn,f
  goto $-8
  clrf gpio
  retlw 00
  ;seq12  fast fade up down
seq12 clrf fadeUp  ;
  clrf fadeDwn
  bsf  gpio,1
  movf fadeUp,w
  call _ZuS
  bcf  gpio,1
  movf fadeDwn,w
  call _ZuS
  decfsz fadeDwn,f ;
  goto $-8
  bsf  gpio,1
  movf fadeUp,w
  call _ZuS
  bcf  gpio,1
  movf fadeDwn,w
  call _ZuS
  decf fadeUp,f
  incfsz fadeDwn,f
  goto $-8
  clrf gpio
  retlw 00
  ;Store   Store the 15 steps in EEPROM
Store bsf  status,rp0 ;select bank1
  clrf eeadr
  movlw .48
  movwf temp1
  movlw 2Fh
  movwf fsr
  incf fsr,f ;fsr starts at file 30h
  movf indf,w ;retreive data in file 30h
  movwf eedata  ;
  call  write
  incf eeadr,1
  decfsz temp1,f
  goto $-10
  goto Main
write bsf  status,rp0 ;select bank1
  bsf  eecon1,wren ;enable write
  movlw 55h   ;unlock codes
  movwf eecon2
  movlw 0aah
  movwf eecon2
  bsf  eecon1,wr ;write begins
writeA btfss pir1,eeif ;wait for write to complete
  goto writeA
  bcf  pir1,eeif
  bcf  eecon1,wren ;disable other writes
  retlw 00
;* Main        *
Main clrf sequences
  movf sequences,w
  call table2
  btfss gpio,5  ;Is swA still pressed?
  goto $-3   ;SwA still pressed
  movf sequences,w ;SwA released
  call table2
  btfss gpio,4  ;SwB puts current sequence at turn-on
  goto Attract
  btfsc gpio,5
  goto $-5   ;SwA not pressed
  incf sequences,f
  movlw .12
  xorwf sequences,w
  btfss 03,2
  goto $-12
  goto Main
;*EEPROM           *
  org  2100h
  END
iceng3 years ago
It has been a while since I wrote pick assembly,
when you do a goto $+.10 what does it move ten lines or ten bits relative ?
Does the assembler warn you if you are crossing a bank boundary ?
What error messages do you get when you assemble it ? You don't "compile" assembler programs, you assemble them.
