loading
black,red,green and white power cable supplying cree 3led bike light is broken.
 I need help identifying which colour goes to which point.There are four points marked A G V B  on the PCB and i need to solder the 4 colours  onto their respective correct points.The cloured cables are coming from the battery and will be soldered on the cree LED pcb.
iceng3 years ago
Red, Green, Blue
What is the Cree LED part number
A battery usually has only two wires.
We need more details ?
What is actually broken ?
teemandi (author) 3 years ago
Thanks for your replies everybody.I can't see any part number.but I should say this is forhhigh power bike light and has dim switches ,maybe the other wires ha ve something to do with that.
iceng teemandi3 years ago
  • You can take pictures with any phone
  • eMail them to yourself
  • SAVE them to a file (call it ibles or whatever you like)
  • Rotate them right for proper viewing
  • Log on here
  • Under your page picture click Image Library
  • Then select  Choose Files
  • Find your ibles file and select a picture
  • Press open and then Upload Files
  • Now the picture is in your library and can be added to your question.
Make and model would be a help.
AGVB is red green white black.
Joe
I don't doubt you but would dearly like to know the derivation A=Red.
Then given four wires, one has to be common Anode or common Kathode wire.
I said make and model would help.
It is not a standard yellow (Left) green (Right) brown (Running) white (Ground)
A red left, G green right, V white ground, and B black running
I have done a few tail lights
AHhaa ..... I get it
Lots of newbies forget to czech up on their question
After all this is a discourse.
I could have said that better also.
Standard North American vehicle lights wiring color code is yellow (Left) green (Right) brown (Running) white (Ground)
But we live in a global economy so you are bound to run into something different.
