3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
camera's wont work with batteries?
i got 3 different camera's, and they all 3 fail with multiple brand batteries.
they start up, work the lense out, and then turn off.
then, when i try to restart it, the same thing happens, only now the lense goes in, instead of out.
it appears to be at least 3 different brands of batteries, all with 3 different camera's.
the batteries that DO work, however have ran out.
how is this possible? they all measure 1.5V (-ish, like all batteries) even the ones that did work.
is it possible for manufactors to let theyr devices only accept a certain brand of battery?
May 13, 2010. 10:08 AMorksecurity says:
Are you trying to use standard low-cost batteries? Many (most?) cameras draw a lot of power, and require NiMH or Lithium batteries. Mine, for example, will power up on a fresh set of alkalines, but die almost Immediately in much the way you've described.
Older battery technologies just can't keep up with the camera's needs.
May 13, 2010. 12:47 PMAndyGadget says:
It's not the capacity as such (although newer batteries will have higher capacities) but the instantaneous current the camera can draw from the battery.  If the battery cannot supply a sudden peak in current, the voltage drops and the camera turns off.
I use 2450mAH AA NiMh rechargables in my camera and1000mAH AAA for other high-demand items.
May 14, 2010. 12:45 AMAndyGadget says:
They're widely available (check your local eBay and Amazon) but in a camara I'd recommend the Uniross Hybrio batteries.   A bit lower capacity but the thing about the hybrid batteries (Eneloop, Hybrio) is they have a much lower self discharge factor which is useful in a camera.  Self discharge is the discharging of a battery when it's not connected to anything and can be quite high, e.g. 50% of the battery's capacity in 30 days.
May 20, 2010. 3:04 PMorksecurity says:
Interesting tip re the Hybrio batteries; I haven't heard about them before.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
