loading
can DIY hot air soldering iron solder other smd component such ic, transistor,and other smd component.?
without destroying anything,especially the board,
hore (author) 6 years ago
hiiii.
Like Sean says, I can't see why it wouldn't work, if you are careful. Its a bad idea to dump too much heat into the board too quickly - you can literally crack SM resistors and capacitors from thermal expansion.
