can I make a coilgun using a relay?
i want to know if i could build coilgun with a relay because i know it is an electromagnet and my coil i was using got tangled up.and giv me an idea of a circuit if i can use a relay.
iceng4 years ago
A relay coil is designed to move the clapper ( armature ) only.
If you remove the coil assembly there is an electro-magnet air tube that might pull a B•B to the center of the winding.
With a 555 timer you may cause the B•B to pop out the top of the coil.
You may call it a coilgun,  I will call it an insect fart .
A
masterzeb318 (author)  iceng4 years ago
So where can i find a electro-magnet air tube?
On many relays it is a simple screwdriver job to separate the coil winding
from the relay assembly by sliding it away from the round rod magnetic
metal frame leaving a coil with an empty air tube for your fun.
A
thank you.
Yes you can use a relay or any coil for that matter but it may not be powerful enough to move your projectile like you would want.
masterzeb318 (author)  mpilchfamily4 years ago
So i will need about 3 or 4 relays?
Check out the coil gun instructables to the right of this page and see what is needed. At the very least you can use the magnetic wire from the relay to make the coil(s) you need.
ohhh ok thanks
How do you propose to use a single coil to make a coil gun ?
