can I run a 1 ohm stable amp with 4ohm subs wired to 2 ohms ?
I have a Hifonics Zeus 3216 and 2 sundown sa12 d4s. the amp is a 1ohm stable so can I use it to push them safely?
iceng9 months ago
Please draw it !
1+
It works with no problems - if you wire all correctly!
I can not really recommend using speakers in series, only in a parallel configuration.
Needless to say that for these low OHMS you really need thick and quality speaker cables - cables, not wires!
steveastrouk8 months ago
Yes, if the amp is stable, you should be OK.
