can a computer's dvd drive be modded to connect to a computer with USB?
8
answers
Answer it!
The USB/IDE cables are good for temporary use, but not as tidy as a case with built-in power supply.
IDE = parallel
So, you need an adapter (connectors plus a simple converter chip), as mentioned; you will need also to feed your internal DVD with the +5V and +12 V it usually gets from the 4-wire connector inside the case.
http://www.geeks.com/details.asp?invtid=ADA-2012&cat=HDD
http://www.geeks.com/details.asp?invtid=2020&cat=HDD
http://www.geeks.com/details.asp?invtid=2020-OTB&cat=HDD
