can a double a battery pull out 1 amp?
if its rated 2000 mah it should be able to right?>
iceng5 years ago
Consider the AA will drop in voltage as it is discharged.  .  .  .   A
astroboy9075 years ago
Yep- it may get a bit warm.. Tough I wouldn't go much over 1 amp because most batteries designed toda only have a limited output current.
Oh- and it should put out 1 amp for about 2 hours, give or take a few minutes
In general Its mAh rating doesn't tell you its output current rating, but a AA can put out an amp.
