can anybody show me how to open the lens of pentax Optio LS1000. its lens stuck in the middle???
can anybody show me how to open the lens of pentax Optio LS1000. its lens stuck in the middle??? i've already open the camera but opening the lens part is risky...so i need some instructions to open the jammed lens...
Jan 22, 2013. 5:06 AMmpilchfamily says:
Its a fully sealed assembly. You won't be able to take it apart and put it all back together again. You'll end up breaking pieces trying to take it apart. Chances are a gear in the assembly is stripped and you'd be hard pressed to find a replacement for it. Check around ebay and see if you can find a replacement lens assembly or busted camera of the same model that still have a good lens assembly on it. This is just one of the growing number of consumer products that where never designed to be serviceable.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
