loading
can anyone give me a rough description on how to build a comunicator for a dc motor?
I have a basic wooden axiel and on it ive placed 3 smaller coils of wire but i need to know how to build the part where the burhes connect from the battery to the axiel. also how far should i have the magnet spacing?
Sandisk1duo8 years ago
i've read a book about this stuff maybe 4 years ago
you can make a commutitator by sanding the metal part of an eraser, then cutting it
go to your local dollar store, pick up a RC car, take it apart, take apart the motor
NachoMahma8 years ago
. Commutator should get you started.
You only beat me to it because I wrote a description :D well done ;)
. GMTA ;)
frollard8 years ago
Helping search first: The item you want to build now is a COMMUTATOR -
The simplest setup has you hook up the 3 coils in series, with each connection point being one of the pads on the commutator. connecting power to any 2 points makes those points attract the magnet, then as it rotates, the polarity of that set of coils is reversed.
check it: http://en.wikipedia.org/wiki/Commutator_(electric)
Using 2 coils is fundamentally the easiest way to explain it.
