can i completely replace lpg with hydrogen to run a car? so that hydrogen is used as the primary fuel source.
i want to know if its possible to replace the petroleum gas in a lpg powered car with hydrogen that i can produce myself and fill the cars gas tank with... if not is there a ratio of hydrogen to lpg that get good results?
NachoMahma6 years ago
.  Not using the installed equipment. LPG tanks aren't designed to hold the pressure required for Hydrogen. The piping is not appropriate for H2. Regulators are different. &c, &c, &c.
grimgroper (author)  NachoMahma6 years ago
http://www.switch2hydrogen.com/h2.htm yeh thanx i did a bit more research this page basically some it up pretty well.. still keen to get onto hydrogen fuel.. "1. If you choose to store the Hydrogen as a compressed gas, you'll need HUGE tanks, and many of them, since Hydrogen isn't very dense, so a tank really can't hold all that much. In addition, you'll be driving a giant bomb. In a collision, expect to die in a huge fireball/explosion. 2. Choosing liquid does solve the density problem since liquids are far more dense than gasses, so you can reduce the amount of tanks and their sizes required to power the car. The new problem that pops up is the fact the liquid Hydrogen in cryogenic... in short REALLY cold. It requires vacuum-thermos ( dewar ) tanks and vents to exhaust the boiling Hydrogen gas. You'll also have to find a source for liquid Hydrogen which is far more expensive than Gasoline. You've also now increased you danger factor when it comes to a collision. Not only will you have more Hydrogen gas spewing around that's going to explode and burn, but you'll also have a liquid spraying about that's over 400 degrees below zero. Once you add in the added complexity of the system due to the cryogenic liquid, your vehicle will wind up being a giant, low efficiency, rolling bomb that costs more than your house, and costs far more to run than it did on Gasoline. 3. The 3rd option is simply the only way to go. There are materials call Hydrides that absorb Hydrogen like a sponge absorbs water. Typically, the tanks are filled with granulated Hydrides, and Hydrogen is pressurized into the material. Hydrides have many advantages over liquid & gas. One is that the density of the Hydrogen stored in the Hydride can be GREATER than that of liquid Hydrogen. This translates directly into smaller and fewer storage tanks. Once the Hydride is "charged" with Hydrogen, the Hydrogen becomes chemically bonded to the chemical. Even opening the tank, or cutting it in half will not release the Hydrogen gas. In addition, you could even fire incendiary bullets through the tank and the Hydride would only smolder like a cigarette. It is in fact, a safer storage system than your Gasoline tank is. Then how do you get the Hydrogen back out? To release the Hydrogen gas from the Hydride, it simply needs to be heated. This is either done electrically, using the waste exhaust heat, or using the waste radiator coolant heat."
From a reply like that - just what is it you were asking in the original question?
L
Woodgas contains CO and H2 and can be made ON the vehicle, it has a much lower octane number than ordinary gasoline, and you can't get the same power from it.
