loading
can i fly a one man helicopter with an electric motor and how much hp will i need?
iceng5 years ago
Small helicopters need 1HP to lift every 10 Lbs at sea level on Earth.
You have to add the Structure wight 485 Lbs
Your own body weight 110 Lbs
The motor weight ___ Lbs.  You will need to develop 48 to 60 HP
And the battery weight ___ Lbs.   Hope you click best answer.
You might be interested to learn, a pound of battery might get you 100 watts,
and a pound of gasoline will get you 1300 watts ......................   A
aryya iceng1 year ago
hi,
Then what is the technical s for this copter. also can u share the average speed, highest at a stretch flying time, total weight, type of engine, safety etc.
iceng aryya1 year ago
Sorry guy, I was making the case that you CAN NOT hang out under an electric prop. Did you even try to Google a 50HP electric motor weight like the kind of advanced design the Tesla electric car is using and work the formulas ?
aryya1 year ago
hi lemonie,
this 2-stroke gasoline engine for two main rotor of opposite directions ?? or one 2-stroke for main and one two stroke for tail rotor ?? can u recommend any good video or technical article to make a one man helicopter ??
lemonie5 years ago
2-stroke gasoline engines give you far more power-for-weight, you'll not get very far at all trying to use electric motors. Also, you'll struggle to control these things should you get one off the ground.
L
kevinhannan5 years ago
your local microlite/air craft club will be able to tell you much much more and safer, too!
orksecurity5 years ago
Not legally, not safely, probably not at all given the weight of batteries but that's a guess.
