loading
can i power my minty boost with these D cell batteries ?
will i get more charging hours by using them?what is the maximum number of D cell batteries i can use in series to power a minty boost circuit?or how much input voltage can i give to a minty boost circuit?
Picture of can i power my minty boost with these D cell  batteries ?
You can only series connect TWO cells, before you upset the Minty-boost circuit. You CAN parallel connect identical new batteries though.
The batteries you have are quite small capacity. They may well be AA cells in a D cell case. Typical modern AA will hold 2800 mAHr -twice what your "D" cell will, in half the case.
imakethings (author)  steveastrouk7 years ago
then what is the use of those bulky d cell alkaline batteries??
That's a very good question.
Leclanche dry cells, which these cells are supposed to emulate have a much lower capacity than modern rechargeable technologies, and I think its an obsolescence thing. If you are designing for recharging, you probably wouldn't use D cells anymore.
thank you for your response
