can someone help me put an output jack on my guitar amp? and help with my amp stand?
so im building a guitar amp stand made of wood. my future plans are to put up to 4 12-15" speakers in the stand. i dont have the speakers yet but i plan on getting them soon so i need a way to put an output jack on my amps. I had plans to simply attatch a 1/4" jack to the leads from the amp speaker but I now have second thoughts about this because of the fear of doing damage to them (i had the same problem with my computer speakers and I blew out the amp) so how else could this be done?
amp 1 --
-guitar amp
-19W
-transister
amp 2 --
-bass amp
-35W
-transister
i dont know if this information helps at all
i also want 3 separate channels 1 for each amp (i might possibly get another amp so i want to be prepared)
if one is a bass and the other a guitar amp do i need bass speakers or will any do for the Bass
i want to control the volume of each channel separately so i will need to know what kind of potentiometer to get
and i want the sound to be decent if one amp is not in use at the time
basicly i want the stand to act like a high proformance cabnet with volume control and separte channels
can this be done?
Ive drawn a design is the wireing correct or can it be beter
Apr 22, 2010. 11:34 AMlemonie says:
The volume should be controlled on the amplifier inputs, not on outputs to speakers. A purpose built bass speaker will perform better than other speakers, but you'll still get noise out of either.
L
Apr 22, 2010. 1:33 PMlemonie says:
Potentiometers of the type you're thinking of don't handle power (see other comments). Wire them into the amp inputs instead.
"Any" speaker is going to work, but bass cones work better at reproducing low frequencies. By way of example: you can have a bike race on any bike, but a racing bike will beat the pants off a ladies-shopper.
L
Apr 22, 2010. 2:25 PMlemonie says:
You put the pots on the signal inputs to the amp. For outputs you can use filters to split frequencies, not very complicated or expensive.
L
Apr 22, 2010. 2:55 PMlemonie says:
Run the wires from the amp to the stand if you want it that way, or put the amp in the stand, but don't try running pot volumes controls on the speakers - it won't work for you.
Filters allow you to split the same signal between different devices, you might find them useful.
L
Apr 23, 2010. 1:24 PMlemonie says:
Your output is what goes to the speakers, but they need to be matched. What is the specification / technical details on the amp (that isn't blown)?
L
Apr 24, 2010. 2:19 AMlemonie says:
They sound much better than the computer-speakers, but do they have an ohm-rating? These things need to be matched, if not either the amp or the speakers can be damaged. If you haven't yet bought speakers, ask in the shop.
I'm thinking of an arrangement like this, but maybe your filter would be better on the input side (not sure)
L
May 2, 2010. 10:09 AMlemonie says:
The Amp' output goes to the speakers, which you separate into bass & otherwise. I'm not sure what you mean?
L
May 4, 2010. 12:12 PMlemonie says:
Squares with arrows are your potentiometer volume controls.
I'm not sure what you mean about adding an output to an amp' - as it will already have one?
L
Apr 22, 2010. 4:55 AMframistan says:
You have gone to a lot of work to describe what you are building... however, it is still unclear (to me anyway) exactly what you are wiring up.  It looks like you are wiring volume controls in line with the speakers.  For that to work, the volume controls would have to be rather high powered wire-wound pots... unless you are building a very LOW power amplifier???  A SCHEMATIC kind of diagram would be more helpfull to understand what you are building.  Is the amplifier going to be inside the box... or outside feeding to the speakers in the box?  I dont like the idea of volume controls in the line with the speakers (if that is what you are doing).  If you use any kind of 1/4" inch jack... be sure it is the kind of jack that is NON SHORTING.  Some phonejacks have a switch built into them that opens when something is plugged into it.  If ANY KIND OF SHORT is placed across your amplifier FOR EVEN A FEW SECONDS.... you will likely blow out your amp.
I think what you are trying to do is possible... Just be carefull to avoid wiring anything that places a short across the amplifier terminals. Why place volume controls at the speaker?  doesnt your amplifier have a volume control?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
