loading
can u convert a115v stick electric welder to make a gas driven welder and if so how is it done!!!!!!!!!!!
bux box welder 115/220 v
skaar4 years ago
*facepalm* yes, it can be done, get a gas powered generator, figure what the max watts the welder would use, then get one double the output or more. plug it in like you'd plug it into a wall.
NachoMahma6 years ago
.  No. An electric welder uses a transformer. A gas-driven welder uses a motor-generator set.
TIG - yes
http://www.az-zbum.com/welder.upgrade.shtml
or Google "stick welder to TIG conversion kit"
MIG - no
MIG welding requires a Constant Voltage (CV) supply, and stick welders use a Constant Current (CC) supply. The power supplies are incompatible with MIG welding.
lemonie6 years ago
What do you mean? MIG?
If so, the answer is "buy a MIG welder and Ebay the stick welder"
L
