loading
can u take and adapt regular car stereo wires to A/v wires and connect them to an amp without any problems???
my stereo that i have just has 2 A/V outputs and my factory amp needs 4 for all the speakers
trev69177 years ago
Buy somehting like this http://www.orioncaraudio.com/Products/Product.aspx?ProductID=962 .  Problem solved.
andreblue7 years ago
frist you need the right adapter sometimes so that the signal that goes to the amp is right because most amps need rca inputs
then you make sure the radio can take the draw
Re-design7 years ago
If the amp you're using is not set up to take an amped output from the car stereo, your amp won't last long unless you keep the stereo turned down very low.
lemonie7 years ago
I assume the car stereo has Left & Right outputs for speakers. What your amp has in the way of 4-inputs I'm not too sure, but you could surely use only two of them?
The car-outputs should be modified by running them through potential dividers I reckon, but I don't know the spec's of your equipment.
L
If you have wires with no plugs such as + and - wires which you clip onto the amp you can solder the Positive and negative straight onto Phono Jacks/cable
As for it working properly it would depend on your amp maximum watts etc and your car stereo
