can we use any ic as a switch if yes then how ?
i want switching witha ic
iceng2 years ago
You can use these IC as switches and control DC, AC as shown.
iceng iceng2 years ago
Hope u understand a micro or some kind of sensor replaces the push switch...
Soumojit2 years ago
You can use a transistor . A transistor works like a switch. or you can also use amplifier ic .
Sometimes I am amased how much you guys post as a resonse with nothing to go at LOL
It's a gift....
The Irish are born with it, I believe...
All this time and I never knew you had Irish blood!
Well yes, I cut my hand rock climbing on Inishmore a delightful Aran island.
I voiced a desire to see a green Leprechaun and promptly stumbled and fell to the ground. My face 10 cm from a large brilliant green beetle...
Welcome to the finest race on Planet Earth (my wife is Irish) so I have to say that.
We have the same beetle here in Canada it is called the Emerald Mortician. It lays it's eggs in rotting corpses.
Another name for it is a cadaver beetle, there are a number of cadaver beetles sometimes called undertaker beetles, and some even bury small rodents and birds when they lay their eggs.
seandogue2 years ago
yes, by designing a circuit to use them. There are many choices.
Vague question => vague answer
I know this is not going to be of little help, but yes and no.
All logic ICs are switches, a OPamp is an IC and depending on how you wire it rail to rail it can act like a switch.
However you are asking for circuits that number in the millions.
So what IC do you want to use?
Yonatan242 years ago
Do you mean to use it as a relay?
i suggest you use a switching transistor or MOSFET...its a far easy to use and cheap too..it can also handle range of voltages and currents
-max-2 years ago
If you just trying to control power to something small, most any transistor will do the job, but if you want to switch an analog signal to something, a FET, analog switch, MUX, or in some cases, a relay is needed.
MOSFETs can be used in some cases for passing or isolating signals since they sorta-kinda act like electrically variable resistors, but realistically they have a few serious limitations because of the body diode and stuff for passing signals between the source and drain. I have a few TL601 and TL604 chips, which are quite nice but have a pretty high ON resistance.
For strictly AC signals, even simple DIODES can be used! You just capacitively couple the signal to the diode, so it looks like
and by applying a DC offset voltage to the diode, you can control the AC signal. W2AEW has a good video about this.
You usually use a transistor as a solidstate switch. If you're switching AC, you can use a thyristor or triac.
