loading
can you help me build a jet engine?
i want to build a jet engine and i want you to help me
JimJong8 years ago
First of all, it depends on what kind of jet engine you want. I'm pretty sure that valveless pulse jets are the easiest to make though.
hreashi6 years ago
guys! can u help me! i goona build astrong real working jet engine wid out turbo car compressor how can i doo it in a easy way!? please help me or give an advice! my plan is to make housing out of steel thermos! but i dont know how to make the interior shaft? wid propellers and retainers
rickharris8 years ago
this is not a cheap or trivial task but
http://www.john-tom.com/html/Jet.html
has plans
There are plans for pulse jets.
Try http://aardvark.co.nz/pjet/ as a start.
~Bob~
lemonie8 years ago
Like and7barton says. But here's an Instructable:
https://www.instructables.com/id/How-to-build-your-own-Jet-Engine/
L
and7barton8 years ago
The best way is to get yourself a truck turbocharger and then base your engine on that. There's loads of plans for turbo-based jet engines on the internet. I built one myself which powered a go-kart. It ran on propane gas. You'll need to do a fair bit of fabrication, most of which will be the combustion chamber and flame tube assembly. Mine worked, but I wouldn't build one again - it used two years and a lot of cash getting it to work properly. Next time, if there IS a next time, I'll buy an out-of-hours REAL aircraft engine. These can be bought for around the same money as I must have spent in total, and it will work properly in the end. These regularly appear for sale on Ebay.
