can you solder enameled headphone wire?
i need to fix my headphones but i dont want to not be able to put them back. if i cut the wire can i solder it back together?
Re-design7 years ago
Sure you can.
You have to remove the enamel where you want to solder.
You can do this but using very fine sand paper or a sharp knife and scraping it away.
But the wire in headphones is so fine I would use a match or a lighter to burn the enamel then carefully scrape it away with a finger nail.
When it's clean make the connection and solder it.
Yes you can. Just burn the enamel coating off. I do this a lot.
lemonie7 years ago
Yes you can. I doubt that it's coated in enamel.
L
Actually you'd be surprised these days. Especially those dirty earbud types...
Lacquer perhaps. I read enamel as something else.
L
