loading
canoe stability isues, tips over easily when stopped
I am trying my hand at building a canoe and while testing it in a pool it seems to be really tippy when stopped, but manageable when going forward. is this normal, or have I made some mistake along the way?
the canoe is 8ft, plywood and with a V hull. some help/ pointers about how to fix it would be greatly appreciated.
rickharris3 years ago
You have 3 options really.
1. A wide flat bottomed canoe
2. A keel - this helps by providing sideways resistance to the water
3. Fit outriggers - Use foam or pool noodles so they will be very light.
8 ft is very short for a traditional canoe - unless intended for white water in which case it is made t be tippy. - !2 feet 18 inches to 24 inches wide and a draft of 18 to 24 inches is much more normal.
The V shaped bottom is good for strait line work but has no inherent desire to stabalise the stationary boat.
http://gaboats.com/boats/snowshoelassie.html
Triclaw3 years ago
that why most dugout canoes have a stablising ponton
That is the nature of most canoes. Unless you make the center wide and flat bottomed. But this affects speed and maneuverability in exchange for stability at rest.
