It appears to be an bank of 4 seven segment LED arrays, there appears to be decimal points as well as the two dots between the two pairs of numbers so time can be displayed as 12:55, etc.
The board appears to wire each segment out to the connector. In order to drive it from an Arduino, you'll probably need 4 seven segment display drivers chips since the arduino won't have enough output pins to drive each of the pins directly.
These devices are usually common-annode or common-cathode, so you'll need to first discover which it is. You should be able to take a 5 volt supply and a 470 ohm resistor in series and momentarily powering the connector pinsand see what segments turn on. You should be able to determine the entire pinout that way.
That looks like a numerical 7 segment display -- does it light up individual segments when you apply a few volts to some of the pins? Do a little investigation and look for a common ground (or grounds)...
looking at picture 4 -- those 4 beefy resistors in parallel seem to be the 'ground' -- as they all connect to a few single pins, makes me think thats 3 or 4 wires for ground, and the rest are + for signal.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Best Wishes.
