cheap aluminium for cooling transistors and such?
would this make any difference with comercial heatsinks?
only in terms of heat-conduction
i know shape is a factor, but i'd like not to get into that, i could bend the cut-up stair or something
6
answers
Answer it!
The main aim is to provide a good surface contact with the transistors to be cooled and as much surface area for cooling as you need (want - have to have!)
IF the situation is critical and a LOT of heat is generated (I would review your circuit design in that case) then a commercial heat sink will give a bigger heat transfer than anything you will make (more than likely) but for most uses just any metal (copper, aluminium, brass) will suffice if there is a good heat transfer from transistor to heat sink to air.
Fan cooling helps as well.
. Ie, your Al stairs will probably make good heat sinks for low power parts but maybe not so good with higher power components.
. BTW, it's not uncommon for Al alloys to be too brittle to bend very far without breaking.
