um two questions whats the difference between a cnc milling machine and cnc router is it that the mill moved the work and keep the tool stationary and the router moves the tool and keeps the work stationary and the next question is which do you think is better to build i want one for mainly small gears and pcbs to make a larger machine and some gearboxes?
i kno but thats not what i ment lol think about it even when you draw a line with a pencil there is still some depth lol but so small that it doesnt need to be taken in consieration thats why i said that when you think about it 2D doesnt exist
I know exactly what you mean, but if you have no real Z axis control you sure as hell only have 2 dimensions under control, so the machine is a two axis one.
What matters for the machine is the stiffness of the whole thing from job to cutter tip. If the machine is too "soft", you can't cut anything.
You COULD make a milling machine for metal. I'd balk at the idea, though I have a comprehensicve engineering workshop I could make one in. If you go the mill route, you are much better off either buying a raw machine, like a Sieg or getting a scrapped one and fitting new leadscrews and drives.
Routers, with FAR less demanding loads, take a lot less building.
well its more like this i was planning to make a small one to make a bigger one with. i would use the smaller one to make the parts out of wood then cast them in aluminium i figure with a small cnc mill i can make the parts as square as possible so less work for me. but another question is do u think i can use a nbm pm 42l stepper and use some gears to increase the torque could i at least mill aluminium
another 2axis machine would be a lathe. in 3D cnc terms, they'd call it the A axis. and then have an X axis, which is the machine moving the cutting tool across the material. ofcourse then, there would be a set depth to cut into the metal, meaning it would basically just cut down a rod to a smalled diameter.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Steve, who has both.
Steve
