loading
collate notepad file to excel file?
Basically i use to collate the data with the help of this batfile command as below copy *txt link.xls i need a help to copy the numbers of txt file to collate in a single excel file with the below specifictions. I have number of text file that text files has its repective name,what i want to do is to collate the set of text files to a single excel file with the column to be added in the excel file with the respective text file names.
drewbrandon3 years ago
Excel files can be used via fix and open xlsx file
Read article http://www.fixnotopenxlsxfile.fixxlsxfile.com
frollard8 years ago
how many text files, and how much data? You have a non-normalized set of flat files, and need to make a good table of data. Office has 'import data' but you can only use one data source, as far as I know. It imports 'delimted' or 'fixed width' data into columns A carriage return means 'next record' and each delimiter such as a comma is a new data item. Is it quicker to copy/paste the data? How do your text files look now? Can you paste an example? Is it easier to regenerate the information in the text files? Are they formulaic?
