3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
color code on a samsung LCD?
i had this old laptop wich had a burned out motherboard, so i took it apart for parts.
obviously, the LCD screen caught my eye.
this thing has 1 connector, with  bout 40 pins. 5 wires are going to the inverter (i guess taht's it at least) and the rest goes to a circuitry on the back of the LCD.
now, there are 15 wires (D-sub standard right?) going to the LCD, and i would love to know how to wire them, that is, what wire takes what voltage, data, or whatever it needs.
btw, the connector to the circuitry has 20 pins, dunno what that means (multiple ground lines?)
the only chip on the circuitry is labeled: LXD91810
                                                          VS246AB
note, the 6 could also be an 8, some genius used a permanent marker to write a 3 over it, wich makes i very hard to read...
is there any site online that is about these kind of mods? i was looking but couldnt find any...
i have included pictures of what i think is important, please ask if theyr either unclear, you need anything else or whatever :P
any info is welcome and greatly apreciated!
Jul 18, 2010. 11:54 AMlemonie says:
You need controller-hardware (like what was in the laptop). It is a common question, but these aren't "plug and play" monitors, they're just screens. People who sell control-units may be found, but it's easier to find LCD & controller-packages.
http://www.purdyelectronics.com/products/displays/prototyping.cfm
L
Jul 19, 2010. 1:42 PMlemonie says:
In real terms you might be better buying an LCD kit. But in the kits are controllers, if you looked hard enough you might find one.
Video-cards out put to an external monitor in a standard format, the actual displays need something else.
You would have to go looking and research it, and I might do it for you if I din't think you'd manage it yourself.
L
Jul 24, 2010. 1:39 PM8bit says:
The problem is that they will probably use a proprietary data format, not a universal one. Unless you can reverse engineer the format, probably won't be doable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
