loading
command->save(current) results in Guru Meditation Error?
Hi,
I'm using a Sparkfun ESP32 Thing with v2.4.3 of Adafruit IO Arduino library. At the above line, execution ends with an error.
Connecting to Adafruit IO....
Adafruit IO connected.
sending button -> 1
Guru Meditation Error of type LoadProhibited occurred on core 1. Exception was unhandled.
Commenting out the command->save() line it responds to the button press repeatedly just fine, though of course it's not transmitting.
sending button -> 1
sending button -> 0
sending button -> 1
sending button -> 0
sending button -> 1
sending button -> 0
I've had issues with ESP32 previously due to power supply, but running off my benchtop PSU doesn't correct this.
I see the ESP32 addition was in the most recent github commit - should it work with this board?
Thanks, Geoff
bekathwia23 days ago
Sorry, I don't have experience working with that board, and don't have one here to test with at the moment. You might want to try Sparkfun's tutorials to start (since they are designed presumably for that hardware), then once you get it working with those, it might be more clear what is up. You may also consider posting this question in the Adafruit forums, where the folks who wrote that library hang out to answer Qs.
