3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
comp. screen with many ports, TV compatible?
Apart from a VGA plug, my computer screen has a bunch of plugs. One of these is supposed to be a composite video port, but none of my cables fit. Do I need to splice some wires or just move 5 feet to my TV?
(also, I'm not sure if it's PAL or NTSC. or if this would matter.)
If I have to replace the plug on the screen, that's not a problem.
link to screen page
[EDIT]
I made a butt-ugly adapter for the composite port, no luck there.
Another Edit
V=Vertical, not video
Jun 12, 2010. 6:36 PMRe-design says:
Here's a link the the manual.  Look on page #4.
What those connectors do is break up the signal that some older high end video controller provided into r,g,b, horiz. and vert.  You can see that it used a special cable that took the signal out and broke it into the 5 components.
Lots of point of sale computers in stores used this system.
I don't know how you can use it for what you are trying to do.
Jun 12, 2010. 2:39 PMlemonie says:
None of those look like composite-video to me.
You should research the signal-format and see what you can find.
L
Jun 12, 2010. 4:40 PMlemonie says:
I meant to find out how that monitor works with it's RGB an those other inputs.
L
Jun 13, 2010. 3:40 AMlemonie says:
Hi,
  I won't guarantee it, but I think you may be looking at Color RS-170 video or similar. That link explains it, but you'd need to "unpick" the composite signal with some electronic device and output it to at least 4 cables to get the thing to work.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
